Running over VPN
Running over VPN
I am having troubles running NX4 over a VPN. I am getting incessant lockups. I am aware that UG does not support running over a VPN, but I was wondering if anyone has found anything that helps. License borrowing is not currently an option.
RE: Running over VPN
Are you running NX locally with the VPN only used for license data?
Or are you running as a remote desktop over VPN?
I have run both ways in the past usually with no issues.
Ben Loosli
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
If UG crashes or becomes unresponsive, the VPN license server is the last place I'd look.
NX 6.0.2.8 MoldWizard
After a while I figured out that it happened due to the VPN reconnected, so I simply started a command window and typed:
ping -t license.server.ip.adress
And then I let it run minimized, pings every second, but makes sure the VPN won't timeout, it solved the problem for me, but I ping the server 3600 times in an hour
(unfortunately the ping-period in windows cannot be altered, but a .bat file with a loop and sleep should be able to solve that)
Best Regards
Hudson
www.jamb.com.au
