Other than 45¦ Chamfer Dimension
NX 6.0.3.6 It appears that the Chamfer Dimension only works for chamfers that are 45°. Am I wrong? How do you make an associative chamfer dimension for chamfer angles other than 45°?
RE: Other than 45¦ Chamfer Dimension
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
Are your drawings IAW ASME Y14.5? The standard specifies that the only chamfer that may be defined with a chamfer note is one that is 45°. Other chamfers are to be dimensioned using a linear dimension and an angle or two linear dimensions. NX meets the standard in this regard.
Ben Loosli
