Forces on Pump Suction Piping
I need to calculate the force on a fitting upstream of a pump (on the suction side) to determine whether restraint is needed across a flexible coupling at the pump. The reservoir that the pump is taking water from is below the pump (suction lift condition). How do I calculate the forces on the suction piping? Is it based on the suction lift capability of the pump?
RE: Forces on Pump Suction Piping
The instances in which you need to worry about these forces (i.e. those in line with the piping) would be due to thermal growth ( T > 200 F) or for seismic loads. Additionally, some transients events would exert a lateral or axial load on the pipe, such as waterhammer or check-valve slam.
Keep in mind that this information is merely a snapshot of things to consider; I also recommend checking the applicable code you are working to for any additional considerations/requirements.
Your expansion joint, if the axial separation forces are more than you think you can absorb conveniently, your expansion joint will need a thrust collar of some sort and some thrust rods. Tighten these up to avoid play at installation prior to start-up.
You need a long straight pipe run into the pump suction: At least 6 to 10 pipe diameters worth. 8 x 8" dia = 64 inches straight minimum. Preferably more. If you don't you'll lose efficiency, start tearing up your impeller. "A few feet" isn't enough for this size pipe with that 8" 90 deg elbow in your suction run.
I disagree with using a flex coupling on the inlet this way: your pump and piping need to be keep rigorously straight to maintain alignment on the pump shaft, and the shaft seal in particular. You should be able to get that pipe to line up, rather than let the flex coupling permanently take an offset in left-right/up-down position.
Use at least 2 pipe supports between the flex coupling and the pump inlet to grab and maintain the inlet pipe run straight in line with the pump centerline, and additional pipe supports on the far side of the coupling to hold the supply piping from the field.
Don't let the pipe weight cross the flex coupling either!
A flexible coupling helps with this thermal alignment but also helps with misalignment due to inaccuracies by the constructor.
Is the calculation of the force due to requirements of the Owner or are you trying to figure how much the pump will be misaligned by putting a hot through it? I would recommend following the manufacturers IOM to the letter and rechecking alignment after the pump has been run for several hours.
If you need to calc the forces, model the equipment as an anchor and plug the piping back to the previous "real" anchor into Caesar II by COADE and you'll get the best answer.
"If experience was always the only factor, how would we get to the moon?"
http://www.piping-designer.com
