What's wrong with this model (section definition error)
When i try to run an analysis, i get an error that the element is missing a property definition, however i am unable to fix it (i think i have set the properties correctly).
the error i get is this:
 ***WARNING: ONLY A COHESIVE SECTION PROPERTY OPTION MAY BE USED WITH ELEMENT 1
             INSTANCE PART-1-1. CHECK THAT NO OTHER PROPERTY REFERS TO THIS
             ELEMENT.
 ***ERROR: ELEMENT 1 INSTANCE PART-1-1 IS MISSING A PROPERTY DEFINITION; CHECK
           ELEMENT SET AND ELEMENT DEFINITIONS
(2 solid elements and a cohesive one in between)
i have attached the .cae and .inp file so if anyone can take a look and tell me what's wrong, i would greatly appreciate it.
RE: What's wrong with this model (section definition error)
To cohesive elements you have to define *COHESIVE SECTION. In your model you have assigned *SOLID SECTION.
akaBarten
