working inside special places like tanks, etc
There will be temporary maintenance works in special places like metallic tanks or very humid places and our local code demands to fulfill some criteria.
It says that the lighting and the tools shall be of 24V or less, or shall have insulating class II (double insulation), or shall be connected through an insulating transformer.
Of couse our tools are of 220Vac and not insulating class II, and there will be major works so we will need all of our tools to match the needs of the workers, so we'll need the 220Vac inside the place.
In case of insulating transformers, which are the conditions tha they should fulfill? which connection is required and which kind of protection is demanded?
Any reference? (IEC, IEEE...)
I was thinking IT single phase distribution, and only short circuit and thermal protection but I would be grateful to hear your experience or some reference.
thanks in advance!!
thanks in advance!!
RE: working inside special places like tanks, etc
I'm not an expert in this field, but I'd expect GFI to be better and cheaper than using a big transformer.
Lighting is 24V AC for the safety of the workers. Tools are 110V AC centre-tapped earth, which is the standard industrial tool supply voltage for Europe, for the same reason: to reduce the risk to the workforce. Isolation transformers in the UK are to constructed to BS 3535.
What's the reason why can't you provide 110V tools? Most portable tools are available as 110V, unless it draws more than about 4kW or so. That's a big motor for a portable tool, although perhaps not so big for a heater. If there is a 110V alternative - virtually regardless of the cost, within reason - and someone is badly hurt killed as a result of using a 230V tool in a high risk environment then the persons and company responsible for the works will have a very uncomfortable time in court, possibly before an even more uncomfortable time in prison.
I'd have guessed that Uruguay would have been US-influenced, so I guess I'm learning something anyway!
Yes, I'm in Uruguay, here the normal consumer distribution is 380V three phase 50hz, TN-S, if i'm not wrong, it's central europe influence. I once heard that our code is much influenced by spain but I cannot assure.
Same thing in Argentina, but Brazil is different.
Anyway here we have 400V three phase TN-S distribution for field panels, used by maintenance.
It is not possible to buy class II tools, and yes, we have 24V lighting. But for grinders, drilling machines and that kind of tools it has to be with the standard tools.
No worries about three phase, sicne the only three phase loads are welding machines and will be placed outside.
Ground fault interrupters I think not needed in IT single-phase systems, but that was part of my question also!!
By the way... what's centre-tapped?
