How to create a simulation model for isenthalpic (adiabatic) flash?
When I size two phase PSV, I need to run HYSYS for an isenthalpic (adiabatic) flash calculation at 90% of relief pressure to calculate the vapour specific volume.
Could someone guide me how to set up this HYSYS model. The service is condensate, tow phase will be water and steam.
Thanks in advance.
Thanks in advance.
RE: How to create a simulation model for isenthalpic (adiabatic) flash?
Your inlet stream is fully specified: composition, temperature, and pressure. The outlet stream pressure should be specified at the 90% value, the temperature will be calculated. The flow rate is not important, so just pick a number.
Make sure you use a steam property package for this calculation, Peng-Robinson will give you wrong answers.
Cheers,
Joerd
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
