FEA composite material
Hi I'm trying to assign composite material to my component (car front bumper which is not just flat surface) which has material coordinate not align with global coordinate system (when u see in abq viewer). I'm using
*material, type=engineering constants
I need my fiber direction (E1) align with material X coordinate. z normal to the surface.
How do I use transformation or orientation
Please advise ASAP
I have hypermesh as a preprocessor
Thanks in advance
Bipin
Please advise ASAP
Thanks in advance
Bipin
RE: FEA composite material
Your elements will have a default primary direction and a default normal. Figure out these directions and you should be able to reorient them appropriate. Most FEA packages project a vector onto a surface, so if your element is not in, say, the X-Y plane, you may still be able to orient the laminate with an x-vector (1,0,0) and have it work for the entire bumper.
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
"Node news is good news."
