wind and seismic loads
Hi all,
I am doing FE analysis of horizontal pressure vessel.
The wind and seismic loads should be applied on the CG of the vessel.
As am doing FE analysis, if i apply the load on the CG where this point(CG node) should be connected.
If anyone is having files showing the load directions please send to me.
sagar
sagar
RE: wind and seismic loads
But if it would help, you should do the reaction caluclations by hand first and then apply the reaction loads to a specific region you're interested in.
FEA and all other programs are very useful, however rubbish in = rubbish out.
A manual hand calculation should be compulsory for all newbies before being let loose on the easy way out using the software.
Why use FEA to do this calculation?
Seismic loads are best applied as an acceleration, using the gravity function for both horizontal and vertical. Wind can be applied to a side or end, based on your calculations to relevant standards.
