PVC Bond strength to concrete
Does anyone have any published data on the bond strength of PVC pipe to concrete?
RE: PVC Bond strength to concrete
Can't think it would be very good.  We use PVC pipe around tubing to protect the tubing from the concrete.  After we are done - we use a jack hammer or manual sledge to remove the concrete.  Comes off fairly easily esp if there is any residual "junk" on the PVC.
I wouldn't normally look to develop strength there, however, I am in a situation where we need to attach to the PVC for a minimal amount of load and I want to verify that I will not pull the PVC away from the concrete. We could possibly perform an in place test on the condition, but, I was hoping for a bond value to start with.
Can you "key" the PVC?/ Insert bolts, nails, screws, etc - just something to give you some "bite" and load transfer??
Nope...The PVC was embedded in the pour.
