Remove Elements from a model
I am simply modeling a 2d rectangular solid with a very fine mesh. Within the rectangle there exists some gaps which at those locations I do not want to define any elements. I am using a parametrized input file so when I build the model, the easiest way is to use *ELGEN to define elements across the whole rectangle, but I don't want elements at the gap locations so is there a way to remove certain elements defined by *ELGEN?
Also, at times I am interested in removing elements from a elset. Is this possible?
Thanks!
Thanks!
RE: Remove Elements from a model
Gurmeet
Gurmeet
Time is an illusion. Now is the only thing there is.
