grinding on a Sec VIII Vessel
I have a ASME Sec.VIII Pressure Vessel with a tread o-let that the bead is keeping a thermowel from screwing in. I am asking, Is it permissable to grind a little on the bead, so the themowel will pass and not interfere with the code.
RE: grinding on a Sec VIII Vessel
Yes, if you don't undercut the weld.
Mike
It is permissible by ASME Code to flush grind or flat top groove and partial penetration welds.
