differential and RSE different results with labview
Using a function generator I made a signal with ground and signal to test a program. The program worked fine. But I found that labview reads a different signal for RSE (signal att. to ai0 and ground) and differential (ai0 and ai8).
The signals show a sin wave but the differential sin wave seems to be interrupted every 1/12period or so.
Can anybody explain this??
Tasio
RE: differential and RSE different results with labview
That is odd-
What model DAQ card are you using?
Are you reading any other inputs along with this one?
Have you tried bias resistors on ai0 and ai8 to AIGnd?
-AK2DM
"It's the questions that drive us"
Also:
Did you set up the input configuration (RSE, DIFF) of the channel in your vi to match your wiring scheme?
-AK2DM
