current split between neutral and earth
On an overhead 4-wire multigrounded neutral distribution system, how much current is typically assumed to split between neutral and earth?
We typically assume a 50 - 50 split and use this result for voltage drop and fault calculations. I was just wondering if this was commonly followed.
RE: current split between neutral and earth
For voltage drop studies, you usually use the sequence impedances in a sequence phase impedance matrix rather than using a split between ground and neutral currents.
See Distribution feeder line models; Kersting, W.H. and Phillips, W.H., IEEE Transactions on Industry Applications, July-Aug. 1995, Volume: 31 , Issue: 4
Abstract
Starting with a modified version of Carson's equations, this paper develops distribution feeder models that can be used in the power flow and short circuit analysis of unbalanced three-phase distribution feeders. A simple line section is used to demonstrate the differences in voltage drops that occur between the various models for load conditions varying from balanced to very unbalanced
