AISI 6150 Heat Treat
It would be nice if some one could share after though harden heat treat data of actual parts contraction or expansion.
We are making a hollow gear shafts about 6" long
Unfortunately, I cannot post a print because of customer proprietary issues. Through Harden Heat Treat to 44HRc.
AISI 6150 Steel
I am looking for actual inch per inch expansion or contraction.
Any issues with distortion.
RE: AISI 6150 Heat Treat
What is the quenchant? Are you able to provide wall thickness?
.133 In. Thick wall
salt or oil (mar temper or mar quench)
