bending a "part"
bending a "part"
Hello you all. I have to draw a small blade that has a very particular shape and a part of this blade is bended of 15°. I have drawn it in "part" section but now I dont know how to bend it. I hoped I could import it in sheet metal section to do the bend but I wasn't be able to do it. Any ideas to solve my problem?
Thank you ^_^
Thank you ^_^
RE: bending a "part"
you can import the part into sheet metal (as Design Body). But
the you have to use the function 'Convert to Sheet Metal'. This will only succeed when the plate/part has a uniform
thickness. When this is done you can apply a bend to it
dy
