ProE WF5, Spacepilot
I have installed WF5 & now the 1-6 buttons, fit & view buttons are not responding.
I have installed the lastest driver from the 3Dconnexion web site.
Has anyone else had this problem?
RE: ProE WF5, Spacepilot
I only recently was able to use it with WF4 before then it was missing. See if you can show the 3dconnextion toolbar with WF5.
Also check that the deice LCDs light up you may need to pop it out and re-connect the USB slot. You may see an error message when launching Pro/E if the device was not detected by the driver.
Michael
