Object as Light source Issues
Hi All,
I've been playing with the Lighting Appearances and emissivity settings as of late and I noticed something that was bugging me when I was working on a rendering for the current render contest.
If I render a scene with the taillight (Appearance is Red Neon) set as a light source I get shadowing on the entire floor. However if I switch off the taillight as a light source I get a much nicer shadowing on the floor. How do I get the taillight reflection from the Left image with the floor shadowing on the right?
60% of the time, it works every time.
RE: Object as Light source Issues
Rob Rodriguez CSWP
www.axiscadsolutions.com
www.robrodriguez.com
http://www.robrodriguezblog.com
Eastern Region SWUGN Representative www.swugn.org www.nvtswug.com
SW 2007 SP 2.0
I'll try it out on a few different systems to see what happens.
Maybe try PhotoWorks? Of course the whole look/feel would be significantly different than what you've got started there.
Jeff Mowry
www.industrialdesignhaus.com
A people governed by fear cannot value freedom.
I'll try it in 360 to see what that does.
