Hydraulic Diameter
Hydraulic Diameter
Hydraulic Diameter
I know that for duct flow Dh=4hb/2(h+b) and that for a pipe the hydraulic diameter is just the ID of the pipe.
What diameter would you use for a hollow pipe? i.e like the outer pipe on a pipe in pipe heat exchanger.
Thanks for any input.
RE: Hydraulic Diameter
Do a search here on "annular flow".  This has been discussed many times before.
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
