Nastran simulation- NO Results
i have followed a given tutorial in NX6 documentation. i did all the steps correct and solved it.. and NX showed it was completed. but then when i go to post-processing navigator.. it don't show any results where it should show according to the documentation.. pls help.. how to see this results.
RE: Nastran simulation- NO Results
Current resource limits:
Physical memory: 2047 MB
Physical memory available: 1330 MB
Paging file size: 4095 MB
Paging file size available: 4095 MB
Virtual memory: 2047 MB
Virtual memory available: 2010 MB
NX Nastran started Mon Oct 12 22:03:58 SLST 2009
22:03:58 Beginning Analysis
All SSE XMM operations have been enabled.
All MMX operations have been enabled.
22:03:58 NSINIT: *** NSINIT ERROR 70 *** UNABLE TO OPEN UNIT 8
22:03:58 NSINIT: STOP
22:03:58 Analysis complete 3
FORTRAN STOP NSINIT/NSCLOSE
Real: 0.132 seconds ( 0:00:00.132)
User: 0.031 seconds ( 0:00:00.031)
Sys: 0.046 seconds ( 0:00:00.046)
NX Nastran finished Mon Oct 12 22:03:58 SLST 2009
at end it says unable to open unit 8.as shown above. is that the prob?? how to fix it??? solving operation completed correctly... seems like the prob it NX dont write results.. pls help
You have to update your NX Nastran software as is experienced the famous April 1st, 2009 "Date Check" error.
Siemens PLM has resolved the problem with a software patch that changes a binary integer value and in effect changes the date check algorithm to allow the program initialization to proceed.
Patch can be downloaded from http://ftp.ugs.com (you will need a valid WEBKEY), check your local GTAC for assistance.
Best regards,
Blas.
