Detailing Rebar!!?
Detailing Rebar!!?
Detailing Rebar!!?
I'm a piping designer contracted on a small project; I'm "pressed" into doing the foundation drafting on this project too. I've been around awhile and I've seen afew foundation details (but obviously not a designer in this discipline). I'm working with an engineer on this project, he's contract too and "away" at present. He's give me the basic info, and I'm doing my best to get it right, but I have afew basic drafting issues I need help on.
  First is when you bent rebar obvious there's a radius at the bent, is there a minimum/normal radius to try to achieve in relationship to rebar size (#8)? ...This is a 90 deg. bent & at the corner of foundation. Also when you're looking at a section cut showing the rebar cage, at the corners of this cage, what is "normal" placement of rebar that runs perpendicular to this loop ...at the corners? Is it at the tangent of the bent? ...OR centered in the radius on the perimeter? ...Hopefully the experts can under stand my issues here!?? Any help would be appreciated!
RE: Detailing Rebar!!?
ACI has a detailing manual that you may try to locate.
#8 bar would usually be detailed for a 3" inside radius on the bend, but there are end hook lengths, etc that need to be considered too.  The engineer probably should have noted all this if you aren't familiar with it.
The bars in the corners of the section (longitudinal) should be tied to the "loop" bars, so show them on the inside of the bend.
Hey THX johnnycash! You've answered 1 1/2 of my questions, BUT I'm still unclear, if at the corner, placing the longitudinal bars at the corners, is the bar placed at the tangent of the bent, or centered on the radius?
Usually  centered on the radius.  That is the way I've seen it at least.  I don't know if the detailing manual really even gets down that specific.  Usually just a concrete cover dimension is given to the corner bars.  The concrete contractor knows it has to be tied in the corner and within the ACI tolerances for bar placement.
