Advice on making shaft
This will be a shaft for a needle bearing clutch that needs to be heat treated to 58C. OD .986" by .800" long with M14 thread. Tolerances are .001+- on the OD. This will be a high volume piece.
The plan right now is start with 1" E52100 and machine on the CNC to correct dimensions then heat treat.
Could forging this piece be a better idea? We are trying to keep cost down.
What do you guys think?
RE: Advice on making shaft
upto 5000 pc's
bar feed chucker or screw machine
heat treat
then centerless grind
for over 5000 pc's
multi spindle screw machine
Thank you very much for the input guys.
There are a few things that ring an alarm bell. Looks to me like you have a metric print. Most likely 25mm shaft. I would check the tolerance given. It should read something like this:
25h7 or some other designation. Since this is a high volume part it pays to be sure you are doing it right. I have seen many mistakes made in situations just like yours.
Material: Not D2! almost no resistance to shock. It is very stable in heat treating but tough to machine. Good for high volume punch and dies with a solid punch and die block.
If tool steel - I would go to S7. Otherwise use low or medium carbon steel and case harden.
I really like S-7 but it will not get the hardness required in the OP without case hardening. I believe that D2 gives excellent wear resistance along with adequate toughness for this part. We use it for all our small gear pumps along with most components in the drive system. This is a pretty rough environment requiring a tough material. Some of these parts have been running on a continuos basis for over fifty years.
By using A2 you give up a little in hardness and wear but again I think this part made from A2 will also be good.
We don't find D2 or A2 hard to machine on modern machinery.
If this has a high load case hardening 8620 and finish grinding or hard turning would be the next lowest cost.
Ed Danzer
www.danzcoinc.com
www.dehyds.com
you sparked my interest how would these parts be forged?
from a bar loader as not to cause handling issues.
in other words how would this be automated.
or do you mean forged bar.
the secondary operation would require load & unload,
with an automated robot.
High Volume > 10000 pcs
or > than 100000 pcs
or > than 1000000 pcs
A-2 & D-2 are expensive materials,
I guess with out knowing the exact application & budget
it could be cheap material like AISI 1095 or is corrosion an issue.
Madbrace
what qty's
centerless grind could be avoided by not recomended to so for bearing application.
Qty will be around 2000-5000 pcs a month.
I whole hardly agree with you about the part in the OP. I guess I'm too old to change my way of thinking, have to watch the loading on the brain cells, that in making a part or component start with the best possible and work down form there. Fortunately I'm not a straight line thinker as I have been certified a "zig-zag" thinker by testing. In other words I can change my approach on fly no as a sycophant but by thought and reason.
Like I'm still thinking about making this particular part by rolling the thread on the appropriate stock , heat treating and the centerless grinding.
And as you say we don't have a handle on this part to where one is able to look for the best approach to making it.
Shafts for the automotive industry are cold formed/forged on horizontal presses (also called headers, cold formers, etc.) or on vertical presses (both mechanical and hydraulic). Typically these are not one-piece flow items, meaning that the parts are accumulated into bins rather than proceeding directly to the secondary machining operation via a robot or conveyor system. The bin of formed parts is then transferred to a machining cell where it is either manually loaded into the machine or some type of automation is used with a robot, conveyors, etc. Parts are handled extremely carefully after machining, on the way to the final processes (heat treating, grinding, etc.).
There are any number of ways to approach manufacture if your part if you go with thread grinding for finishing.
http://www.drakemfg.com/threading.htm
http://www.bostoncenterless.com/index.htm
