Highest yield strength for 1/16" diameter wire.
I am looking for wire in 1/16" diameter that has very high yield strength, but is also readily available.  Is there something out there better than music wire?
Jim
RE: Highest yield strength for 1/16" diameter wire.
Rocket wire is the ticket.
Just be careful with it, limited ductility.
If you pull a tensile test make sure that you have shielding.  Not all of the sample will be there after fracture.
Plymouth Tube
