Looking for large dia o-ring
I am looking for a large dia o-ring. Hopefully there is a standard size out there with an id of approx. 30".
I've found "make you own" o-ring kits but do not have any experience with how well they hold up in use. Does anyone have any experience with the adhesive type or the vulcanized type?
RE: Looking for large dia o-ring
Its a long shot but sizes like this may also be available in larger cross sections (1/2 to 3/4") from oilfied elastomer suppliers. Stewart & Stevenson www.ssss.com is one supplier that comes to mind. Also if you need more than one or two, o-ring molds are 'reasonably' cheap to have made.
These people have a 30" O ring listed
http://www.applerubber.com/include/pdf/oringsiz.pdf
Try http://www.apandg.com/vulcanizing.html
American Packing and Gasket can make the ring you need, and they might even have it in stock.
Gunnar
