Adding "Float" feature to a rear-mount snow plow
This is probably a very simple question for many of you. We are building two back blades for snow plowing. Our hydraulic circuit is very simple, consisting of a double-acting 12VDC power unit and cylinder. This gives us power up/down. Any suggestions for circuit design to add a "float" mode, so we will have power up, gravity down and power down?
RE: Adding "Float" feature to a rear-mount snow plow
http://www.brand-hyd.com/ts/ts-info.htm
Ted
