Plots with force units not correct
I am having an issue with plots. If I write a function that uses units of force the function evaluates correctly but the plot does not. If I use mass units both work fine. Attached is a pdf sample of my problem.
I have set the units system to custom, based on SI, with the length unit changed to mm.
Thanks for any help.
http:// files.engi neering.co m/getfile. aspx?folde r=fe5ab0bf -f433-4f28 -a393-c5e9 f5ef8965&a mp;file=fo rce_plot_p roblem.pdf
http://
RE: Plots with force units not correct
TTFN
I attached the actual mathcad file this time.
TTFN
