Double angles as beams
Has anyone used double angles to support concrete slab and metal deck? Looking at 2" deck with 3 1/2" of concrete (5 1/2") total. I'm getting conflicing advise: been told using anlges as beams is against AISC, but 13th ed has provisions for checking in biaxial flexure. 9th (green book) does a well. My max span would be 6' with a live load of 100psf. The archy is pushing this system citing the old "we have done this before" clause. My original plan was to use W8's (for easier bolted connections), but the project is being VE'd. My gut feeling is that this design is inherent to problems in the future. Any thoughts or suggestions would be greatly appreciated. Thanks.
RE: Double angles as beams
I agree with the Architect--why overkill with a W8?
DaveAtkins
Why would you say using a single member rather than two angles is overkill? If a W8 is too big, use a W6.
BA
