3RD ANGLE PROJ instead on 1ST ANGLE PROJ
Hello all,
I have a problem with changing the 1ST ANGLE PROJ (current) to 3RD ANGLE PROJ because I have to make the drawings. I can't find the suitable option which could allow me to change.
Maybe someone knows how it would be possible?
Thanks in advance
Gregor
RE: 3RD ANGLE PROJ instead on 1ST ANGLE PROJ
It's set in your Drafting Standards.   Search the forum for information on editing your Drafting Standards and Admin Mode.
You might also check the properties of the Drawing Sheet.
You can also choose which method in Sheet properties.
Thanks a lot for your response.
My problem disappeared after using start model with all settings.
Thank you all once more
Gregor
