Section view label already in use
I have looked through old threads and found Cowski's version of something similar and tried the advice that was given but to no avail.
One of our users has a 3 sheet drawing, each with 3 views (normal and section) all have lables displayed but we are struggling to get all the view labels named in order (A-A, B-B, C-C etc), There are some gaps for example when I try and change one of the views which is named AA-AA to be A-A, it says that the letter is already in use and I certain that it isn't, no view has got hte letter A assigned to it, we are having the same trouble with the letter E also.
Any ideas people?
Many thanks in advance.
Any ideas people?
Best regards
Simon NX4.0.4.2 MP10 - TCEng 9.1.3.6.c - (NX6.0.3.6 MP2 native)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but by the number of times when it's taken away...
RE: Section view label already in use
Maybe something has gone awry, but the trap for new players is usually that there is a detail view or projected view of some other description that uses up the letters that are blocked. I'm also not sure that taking the option of turning off the view labelling frees up the assigned letter. It might be something worth testing.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
I agree with Hudson as we had similar issues and until we got used to UG naming detail views in order with section views, it drove us nuts.
Another idea for you: while in the DRAFTING app, look at the navigator near the top. Under drawing - sheets, you will find all views listed along with the view name. See if you don't find the "A" and "E" views listed.
Bob
