Earth dam under floods
If you have earth dam containing low permeability soil layer and this dam is exposed to flood , it should shear under undrained case. However, in most practice earth dams and levees are usually analyzed considering undrained shear only when they are under rapid drawdown case. Why the undrained analysis is not considered when such dams and levees asr subjected to floods.
RE: Earth dam under floods
