Checking assembly interference.. NX6
I'm doing automotive stamping tools and would like to be able to check for collisions within the tooling and collisions with the part.
Is there a good way to do this? I only need to check it static. The only thing i've found checks between "two" bodies.
TIA
Dave
RE: Checking assembly interference.. NX6
Have you tried Assemblies - Components - Check Clearances
If you have the Advanced Assemblies License - Use Analysis - Assembly Clearance
I would suggest reading the help docs on these topics.
John Joyce
Tata Technologies
1675 Larimer St.
Denver, CO
www.myigetit.com
NX5,6 Solid Works, Solid Edge
