Test data, Mechanical properties
Hi, everyone
I am in need to find data for som kind of elastomers. I have serached the internet without luck. I need to implement the data into a simulation program in order to somewhat get an idea of the mechanical behaviour.
Can anyone recommend a reference book for standard/common types, or is information available on the internet?
RE: Test data, Mechanical properties
What sort of data do you need for your simulations?
In general, any parameters which can define a hyperelastic material physical properties.
From the Matweb home page, select Material Type from Categorized searches. Then selecting from the left links Polymer, Thermoset, and Elastomer (or some of the other categories which may be elastomers as well), then Find. There's some general info, but some specific info on different rubber/elastomer compounds in the lists.
Hope this helps.
Tom Jablonowski, TSE Industries, Inc.
www.tse-industries.com
Did you finf by the end any test data with rubber?.
if is so, could you be able to share this data with me?., please let me know.
http
I knew already about this page, The best for elastomeres and plastic like materials if you want to perform FEA.
I just would like is to increase my data base in elastomers.
For those how has data and want to calculate the constants for different models:
http://www.hyperfit.wz.cz/
