solsh 190 Element orientation with a coons patch
I am modeling a snowboard, a sandwich structure.
I have modeled the board with several volumes, all of which have a coons patch applied to the areas.
I defined the section that I wanted for the sandwich.
I have used Vsweep and successfully meshed the model with the section.
My problem is that my section is oriented perpendicular to the board. I have tried every orientation command that I have found to with no results.
I have attached a screen shot of the elements with the section displayed.
Thanks in advance for any help.
