EM12K procedure
EM12K procedure
EM12K procedure
We are fabricating a vessel from 1 1/4" SA516-70 and our Sub arc proceure uses a Lincoln EM12K electrode which our customer claims is not suitable for PWHT. They did not give a reason. Does anyone know why this electrode is not suitable or which type of sub arc wire would be more suitable. The procedure must meet the same tensile, elongation and impacts as the parent metal. I have contacted Lincoln about this and they are not very helpful.
RE: EM12K procedure
the client is correct.
we use EM14K (Lincoln LA71) with 880M (lincoln)
you should not have any problem with impacts as long as the temperature does not go to low and you you keep you preheats high and interpass temps low.
RE: EM12K procedure
It depends on the flux you use with the wire.  Typical wire flux classification for this electrode is F7A6-EM12K.  The "A" stands for "as welded" and is not tested with PWHT per SFA-5.17
You want a classification with "P" in the designation which stands for "post-weld heat treatment", and is tested per SFA-5.17 with PWHT.  For example F7P4-EM14K.
That is probably why your client is not accepting it.
RE: EM12K procedure
Thank you vesselfab. It looks like the LA71 with 880M or 888 flux will be the answer. To DVWE the client will not accept any procedure with the EM12 class. It did not matter which flux we suggested. We had to change to EM11 or EM14 but I do not know why?
RE: EM12K procedure
typical tensiles after PWHT are too low
RE: EM12K procedure
It seems this would be addressed in the weld procedures- do you have qualified weld procedures with that electrode that meet the tensile requirements, with PWHT?
RE: EM12K procedure
Regrumble,
I doubt there is a classification with a P in it using EM12K.  That's the only reason why.  JStephen brings up a good point, did you qualify this procedure with PWHT?
RE: EM12K procedure
As long as you successfully qualify the wire/flux combination per ASME section IX, it is legal per ASME.  The problem is, the welding consumable mfg's do not "certify" the wire/flux combination in the PWHT'd condition.  This shouldn't matter, since ASME doesn't require this certification, but many welding engineers have gone above and beyond ASME code, and allow only wire/flux combinations that are certified by the mfg in the heat treated condition .
RE: EM12K procedure
might be legal and barely squeak by the pqr.
that's why the users and engineering companies want to approve weld procedures.
would you really want to risk your company's reputation and safety of user's personel with welds that may not be up to tensile after pwht?
lincoln may know best and that is why they put the A classification on the wire.
RE: EM12K procedure
I agree with vesselfab.  The only way this might be acceptable is if the fabricator agrees to test every flux lot and wire lot combination which would be used in production.
RE: EM12K procedure
petronik,
Your WPS is incorrect.  QW-404, Electrode/Flux (Class) should be the classification of the electrode/flux when combined.  for example, you should have something like F7P4-EH12K listed there.
"Basic" means the type of flux.  There are basic and active type fluxes available.  Basic, which I believe also means neutral does not add significant alloying elements to the final weld deposit, whereas Active fluxes will add alloying elements.
RE: EM12K procedure
do you have a pqr to go with that
would like to see the tensile results
RE: EM12K procedure
yes we have PQR.
Ultimated tensile strenght for 8 specimens were:73428~79232(PSI)
RE: EM12K procedure
Vesselfab, I usually agree with your posts.  In this case, let me explain our position.  A few years back, our WPS was rejected by our client on the basis that the wire/flux combination wasn't certified by the mfg in the PWHT condition.  This came as a shock to us since we had easily qualified this combination for the PWHT condition for decades with no difficulties. (Pior to this, we were not aware that it wasn't certified; still, it was legal since we successfully qualified the WPS per ASME Sec IX).
We were told that there were some reasons unrelated to S&T heat exchanger applications that were the basis for the mfg not certifying the combination in the PWHT condition.  I wish I could remember the reason, but it didn't have anything to do with our industry.
Since then, we have switched to a wire/flux combination that is certified by the mfg (btw, we had better results with our original combination than we did with the "certified" combination).
I am not a welding engineer--just my thoughts.
RE: EM12K procedure
There's nothing wrong with using a wire/flux combo which is designated as "A" or as welded in a PWHT situation as long as the wire has been tested (per lot) with PWHT.  When a "P" is present, obviously the manufacturer tests each lot.  All a PQR will tell you is that particular lot of wire or wire/flux will pass tensile requirements.  If a fabricator is willing to do the testing, then what's the issue?  To further note, testing per SFA-5.17 is different than a typical PQR test, as the SFA spec calls for an all weld metal tensile coupon.
RE: EM12K procedure
A good discussion touching on the quality assurance aspects of welding, specifically: does a PQR with one batch of consumables really support production welding with any other batch of the same consumable?  It encapsulates the way consumables are specified, manufactured, purchased and tested: does one accept a certificate of conformity (EN 10204 Test Report Type 2.2)from an SFA-5.01 Schedule G level of testing or should it be an inspection report Type 3.1 for a Schedule J or K level of testing with a highly restricted lot classification, for example?  I would say that the answer depends on what is to be fabricated, the service it will see, and the level of testing that will occur during manufacture.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
RE: EM12K procedure
It's amazing that all those thousands of vessels welded with Lincoln's L61 wire and 860 flux and post weld heat treated with welding procedures qualified with multiple hours of PWHT have not failed. Having said that, the carbon equivalents of welds deposited with that flux/filler composition have decreased appreciably since the mid 1980's.
RE: EM12K procedure
hey
I agree with the fact that thousands have been pwht with this wire and flux and have not failed.
it's a testament to the old 4:1 safety factor
But I just play by the rules that the big boys set up
For me, just a meager little fabricator, it's easier to go by rules and certs set up by Lincoln and use the different flux/wire combo that is just fractionally higher priced than it is to argue with a customer.
Our business is to make cutomers happy with a good product delivered on time with high quality.  Not to argue over a weld procedure that can be fixed easily with a new flux/wire combination.
Sorry guys....it's just easier to comply sometimes.
RE: EM12K procedure
I want to thank all of the contribtors this has been very informative. I have since found out that our client (Flour) did not even look at our procedure (which was qualified and has been used many tiems with PWHT)they just will not accept any with the EM12K as a matter of policy. But as Vesselfab indicated we are also just a little fabricator and are trying to keep the client happy so if I have to do another new proceudre then that is what we do.
RE: EM12K procedure
Usually better to stay with a 'certified' combination if it gives the customer a headache.  Unless you will be using many tens of thousands of pounds, the extra pennies per pound should not matter much.
Also, you will typically qualify a WPS using no thicker than 1.5".  This might buy you 8" in production, but at 8" it will require longer PWHT, lowering the strength of the production work.  If I put myself in the owner's place, I would be wary of borderline acceptable test results on PQRs and how valid they might be for a given design.  Remember, they are representative of given heats of plate, wire, flux, a given welder, etc. (the weather?)
I have done a bit of SAW welding, and found the AWS wire/flux classification system a bit clumsy.
RE: EM12K procedure
Regarding the "have not failed" statements... Those of you making that statement - have you tracked the vessels or have you simply not been notified? More often than not (read 0.1%) when I'm dealing with some type of issue with a vessel we do not notify the original manufacturer. Even if it was a fab shop foul up.
I'm no welding expert so I'll stay out of that arena...
jt
