Application driven holes
Has anyone else ran across this warning?
What does it mean?
Please see attached jpg.
Herb C.
Eifel Mold & Engineering Inc.
Plastics Tooling Designer
UG NX-6.0
RE: Application driven holes
It appears that somehow your standards files (in this case hole data) is not being found by NX.
First thing you need to do is to check that the 'modeling_standards' folder is located in the UGII folder.  And if it's there, that it contain 5 hole standard's files.
Now if that's OK, you need to verify whether the following environment variables...
UGII_SCREW_CLEARANCE_HOLE_STANDARD_DIR=
UGII_THREADED_HOLE_STANDARD_DIR=
UGII_DRILL_SIZE_HOLE_STANDARD_DIR=
...are pointing to the above UGII/modeling_standards folder.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
