Abrasive Slurry Erosion Rate Formulas
I'm looking for a formula that relates pipe material properties and service to erosion rates due to an abrasive slurry.
Thanks!
Thanks!
RE: Abrasive Slurry Erosion Rate Formulas
There are too many variables involved to give you a direct answer. Your best bet would be to perform a literature search, being as specific as possible about your system (media, piping material etc).
Someone is doing work on your subject of interest.
http://www.creare.com/services/fluid/twophase.html
Learn the rules,so you know how to break them properly.
Dalai Lama
_____________________________________
this is for oil&gas facilities:
Erosive wear in piping systems (DNV RP O501):
h
ht
Erosion in Disturbed Liquid/Particle Pipe Flow:
Effects of Flow Geometry
and Particle Surface Roughness
htt
s
Corrosion Prevention & Corrosion Control
