2D 'Model Space'
2D 'Model Space'
So I need to produce a drawing that I would traditionally create in model space and then bring across into the paper space as required... I don't seem to be able to do this in SW. Odd.
Cheers,
M
Cheers,
M
RE: 2D 'Model Space'
Dan
www.eltronresearch.com
Dan's Blog
Many thanks for the quick reply. What I need to create is a set of 2D drawings during a transition stage within the company.
Within SolidEdge, which we used at my last company you could create a 3D part, then create a drawing based on that part (nothing different there). You were then able to enter the 2D Model Space of the drawing, create something then return to the paper space and include it alongside the 3D item...
Cheers,
M
Dan
Dan's Blog
In AutoCAD 2D, drawing would take place within the model space, then you create viewports for the paper space... This is what I would like to do in SW.
Cheers,
M
Chris
SolidWorks 09, CATIA V5
ctopher's home
SolidWorks Legion
Sorry but I've used ACAD, SE and SW and I'm still not understanding what you are trying to do.
If all you want to do is add a sketch to a drawing view, then just click in the view of choice and start sketching. No need to switch spaces.
Thank God Solidworks doesn't work like that. In Solidworks, there are 2 ways that I can think of to manipulate your 3D model. First is if you import your dimensions into the drawing via Insert > Model Items. After importing your dimensions, you can change the dims and the model will update accordingly.
The second way to manipulate your 3D model while in a drawing only rotates the model, but doesn't change it. Pick the view in the drawing then View > Modify > 3D Drawing View and now you can rotate the model or whatever.
All that said, you cannot draw lines or add features to a 3D model while on a drawing layout.
I do know CAD, I've used it for the last 16 years with a range of software. I last used AutoCAD in 2002. In my last company I completed 3 weeks worth of off site training for SolidEdge to enable myself and a colleage to integrate 3D CAD into the company... So my two approaches to try to explain what I'm aiming for was to increase the chances that someone might know what I'm talking about...
So... Ignoring the 3D side of SolidWorks altogether as, here's another go.
Within the drawing sheet of AutoCAD or SolidEdge, there is an ability to view a model space (infinite drawing space) that is not part of the drawing sheet. In that environment you can draw to your hearts content in 2D (this is what I want to do, as I need to create some diagrams). Returning to the drawing sheet, you have the ability to add viewports of sections of 2D drawings in that environment. Creating a drawing.
How's that?
M
The other option is to right click on the sheet and go to edit sheet format. This is traditionally where your titleblock is located. But you can draw there all you want to.
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
You may also try MS Visio...or one of these apps http://labs.solidworks.com/Products/
Chris
ctopher's home
SolidWorks Legion
SW does not have that function. I can imagine scenarios where that would be useful, but never having had it, I don't miss it. If it were available I'm sure it would be used, and (as you are experiencing now) would miss it when not available.
I will try to translate what SolidWorks does into your way of thinking:
If you must, consider the solid model (.sldprt) and the assembly (.sldasm) as being in the model space. The drawing (.slddrw) is the paper space. SolidWorks can then take one or more parts or assemblies in the model space and put them in one or more paper spaces (drawings). In addition you can detail more than one part or assembly (model space) in a single paper space.
Further you can do a lot of the drafting work in the model space and import it automatically into the paper space including GD&T, surface finish, weld symbols, etc.
Hope this helps.
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
"Node news is good news."
If you dimension a line drawn on the model view, it will automatically be scaled to the drawing sheet scale.
www.ingene
Page 11 explains that SE has created a function very similar to AutoCAD within the drawing (draft or paper space) mode.
So it can be used to create views (crops, clips, details, etc) from 2D sketches or layouts.
a. Create an empty sketch (INSERT/VIEW/EMPTY SKETCH)
b. Lock focus on an existing view and sketch within the view.
c. Create a sketch in the model and make it visible in the drawing or convert edges to make it visible.
d. Lock focus on the sheet and make the sketch.
Lotsa possibilities. It's up to you to figure out which suits your purposes.
TOP
CSWP, BSSE
Many thanks to all of you for the help and suggestions. I'll look into the various methods that are available to me. It's a shame there is not the exact feature I'd like to use, but you cannot have it all!
Cheers,
M
-Dustin
