How to wrap a curve on cone and make sth like this
Hello
I`ve got a problem with wraping a curve on cone. I would like to make cone like in the picture and I`m wondering about the best way to do it. Wrap a curve on cone then sweep a circle along guide ( this wraped curve ) and then substract. Could anybody show me how to do it ?.
RE: How to wrap a curve on cone and make sth like this
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Best regards
Simon NX4.0.4.2 MP10 - TCEng 9.1.3.6.c - (NX6.0.3.6 MP2 native)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but by the number of times when it's taken away...
Looking at earlier sweeps I thought that I would have gone to a little more trouble to define and control the section accurately. The only use I've ever had for such a thing was the threaded nut on the inside of a drill chuck. Somebody might relate to that. I used a similar method in an effort to reproduce an accurate thread form.
The other thing I'd mention is the absence of any projection which came about because I have used a helix with a simple linear radius law taking values from the sketch for the first revolve.
I hope that it is relatively easy to analyse the model and understand my method and the intention behind it.
Best Regards
Hudson
www.jamb.com.au
If the grooves have a circular section then why not use a tube feature with zero internal radius and save yourself the trouble of dealing with controlling your sweep feature. In your example it looked to be a round section by the sweep had gone horribly wrong!
Best Regards
Hudson
www.jamb.com.au
