Consumable Insert for butt welding pipe
I know that piping could be butt welded by inserting a consumable ring (see ASME B31.3 FIG. 328.3.2). When asking weld consumable suppliers, they answer that they don't know it (Perhaps here in Europe).
Would you give me a list of suppliers in Europe or in U.S. for this kind of consumable ?
Thanks (M.A., Belgium)
RE: Consumable Insert for butt welding pipe
#1 Ring Road
Factoryville, PA 18419
Phone 570-945-3800
Fax 570-945-3806
Sales 800-526-4392
http://imperialweldring.com/iwr/consumable.html
Imperial Weld Ring
PO Box 6646 E'Port.
80-88 Front Street,
Elizabeth, NJ 07206
Phone us at: (908) 354-0011 (in New Jersey)
(800) 444-7356 (elsewhere)
Fax us at: (908) 354-9014
Hope tis helps
G Austin
http://weldinginspectionsvcs.com
ITT GRINNEL USA
ARCOS USA
WELDRING USA
ROBVON INSERTS, USA
THERE ARE OTHER INDIAN MANUFACTURERS ALSO IF U ARE INTRESRED
As you are indian would you tell me how can an european manufacturer be approved by the IBR (Indian Boiler Regulation) to export to india.
WELL I AM NOT SURE ABOUT THE REPLY BUT IWILL FINDOUT FROM OTHERS. THERE ARE IBR INSPECTORS WHO WILL INSPECT THE PRODUCTS FOR CERTFICATION. THEY WILL BE ABLE TO GUIDE ABOUT THIS ISSUE. IWILL GET BACK ON THIS .
PDPRAO
Robvon was mainly in carbon steel inserts . We have used for carbon steel high pressure piping.
Weldring makes fether edge design , which was used in more accurate fit up and welding
GRINNEL ALSO MAKES ALL TYPE OF INSERTS AND N VERY POPULAR .
