ACI 350 sealant question
There seems to be a slight contradiction in ACI350-06.
R4.8.3 — Sealants
"Non-sag sealants are recommended for submerged service. Polyurethane sealants, single-component, and two-component are recommended. Polysulfide sealants are not recommended when the sealant is in contact with wastewater."
G.3.4.1 — Polysulfide sealant
"Polysulfide sealant shall be a two-component elastomeric compound meeting the requirements of ASTM C920 and shall have permanent characteristics of bond to metal surfaces, flexibility, and resistance to extrusion due to hydrostatic pressure. Air-curing sealants shall not be used. Sealant shall be a type that is appropriate for submerged service when used in fluid storage tanks."
I am surprised that the main body of 350 specifically warns against polysulfide for wastewater contact, and yet Appendix G (wire-wrapped precast tanks) specifically asks for polysulfide in a submerged condition. Appendix G is probably most-often used for potable water tanks, but could also be used for wastewater, I suppose.
There is probably something obvious that I am missing here.
Can a sealant expert offer a recommendation as to whether polysulfide sealant is good in a wastewater environment?
Does it make a difference submerged vs non-submerged?
I have a current concern with sealing concrete joints in a non-submerged wastewater application with high H2S levels.
Thanks for any advice you care to share.
R4.8.3 — Sealants
RE: ACI 350 sealant question
Dik
