NX7 and 3d Connection
I have recently installed NX7 and I've noticed different behavior with space navigator. For one, SN toolbar no longer loads on screen inside UG. Tried downloading latest drivers and no difference. Also inside sketch mode SN no longer locks in XY plane but allows spin/role. Is there an NX setting for this? Can't contact 3d because I bought personal edition.
May have to upgrade.
RE: NX7 and 3d Connection
I've tried that but I have to turn spin/role back on when out
of sketch mode now. Before, settings automatically switched.
As for what triggered the the change I'm (almost) certain that
change occurred after NX7 install. Guess I should spend the $40. and upgrade. Only reason I cheaped out and bought PE was that I wasn't sure I was coordinated enough to manage two devices.
Now of course can't manage without.
You may also need to redefine the UGII_3DCONNEXION_LIBRARY variable.
Specialty Engineered Automation (SEA)
http://www.sea4ug.com
a UGS Foundation Partner
I did notice that the NX6 UGALLIANCE folder had a 3dx folder that NX7 was missing. I copied it in, reloaded nX7 to no effect. Not sure where "UGII_3DCONNEXION_LIBRARY variable" is
located. Also noticed that 3d connection's folder contents end with NX6, even after installing latest drivers. Maybe too soon to support NX7.
Now my buttons work, but the sketcher still defaults to a 3D movement. I end up having to "Orient View to Sketch" then pressing [2D] on the device every time I enter sketcher. Not a big deal, but definately a nuisance.
