Error message in ANSYS Workbench 11
Dear all,
I'm doing a flexible dynamic analysis of an assembly imported from Solidworks to ANSYS workbench 11. I've modified my model many times without being able to solve this problem:
One or more elements have become highly distorted. Excessive distortion of elements is usually a symptom indicating the need for corrective action elsewhere. Try ramping the load up instead of step applying the load (KBC,1). You may need to improve your mesh to obtain elements with better aspect ratios.  Also consider the behavior of materials, contact pairs, and/or constraint equations. If this message appears in the first iteration of first substep,be sure to run shape checking of elements.
Could anybody help me to get this error solved, please?
Thank you in advance.
RE: Error message in ANSYS Workbench 11
Any sugesstion, please?
