Metric Specialty Threads
All,
I am looking to find a chart of metric specialty threads.  Our design challenge is that we have a thin wall (1.5mm) that we need a 3.5mm clearance home and then we are going to thread this hole to screw a retaining cap in place.  If we back off the clear hole to 3.3mm we can then use a standard 4 x 0.7mm thread, but I would like to have a finer thread pitch.  Is there anything out there like a 4mm fine pitch thread.
Rich.....viking2
Richard Nornhold, PE
http://www.ovenind.com
RE: Metric Specialty Threads
Have you tried working the numbers with an imperial thread size?  6-48 is the finest commonly available in that 4 mm range.
Fine pitch for M4 is 0.5mm. Taps/dies should be readily available (but perhaps not if you are in the USA)
Correction:  The wall thickness is now reduced to 1.187mm.  So I guess the question becomes what type of thread could we use that would get us a fine enough pitch to have 3+ threads of engagement.
Rich.....viking2
You can still have 'specials' in metric just like you can have UNS for inch.  Some are even available off the shelf from precision part suppliers like Thorlabs as CBL points out.
Assuming US take a look at ASME B1.13M-2001 section 7.6.
If it's important enough and/or you're making enough of them special threads are perfectly reasonable.  We use them a lot for find adjustment, often parts from Thorlabs or sometimes we have our own made.  In inch things like 80 TPI or even 100 TPI are readily available.  Try finding the equivalent for metric, the link CBL gives may help.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
