Removing concentricity in a sketch
Sketching in SW09 SP3 I have 2 arcs which are unintentionally concentric.
Is there a way of removing the concentricity without having to delete and redraw one of the arcs?
I read that in 05 you could hold ctrl, drag one arc to a new position, and release the ctrl key. This doesnt work for me.
RE: Removing concentricity in a sketch
You will see little icons in your sketch, hover over them to see what they are, simply click and delete the concentric relation.
This is extremely handy and it works really well, couldn't work with them!
CSWP-Surf
Deepak Gupta
SW2009 SP3.0
SW2007 SP5.0
MathCAD 14.0
The arcs were concentric, but there was no concentric relationship present.
Apparently you can't do the ctrl+drag trick while editing a part in an assembly?
Strange given that the part was driven by the assembly, including the sketch in question.
Editing the sketch in the part itself I was able to break the concentricity using the ctrl+drag trick.
Sometimes I move one arc using Tools --> Sketch Tools --> Move. You may end up losing other constraints to accomplish this.
