vertical line in xy plot
Is there a way to graph a vertical line in an xy plot in MathCad?
RE: vertical line in xy plot
Depending on what version of Mathcad you can also put up to two vertical or horizontal lines in a plot.  Double click on the plot, in the XY axis tab, if you have a selection for "show markers", check the box under x-axis.  This will put two placeholders under the x axis.  If you type a number in there (won't accept a variable unfortunately), it will draw a vertical line at that point.  I think this was added in V13.
Peter
