redraw problem
redraw problem
I just started to use SolidWorks adn I noticed right away that some lines of the scetch appear and dissappear as they please. I can correct it manually by pressing CTRL-R every second but it gets annoying when working on a serious project...
Is there a solution to this?
thank you,
thank you,
RE: redraw problem
Right click on the toolbar, choose customize/commands and drag the 'redraw' icon to your chosen toolbar.
Bye the way, if you searched the help topics for 'redraw' it would brobably come up with this answer - it is a very poweful tool.
However, I experience the same problem sometimes and it is due to the graphic card i am using - not much to do about that, though U can change the vie to wireframe or hidden in gray to improve it.
RE: redraw problem
RE: redraw problem
http://www.solidworks.com/swdocs/support/html/videoissues/videotest.cfm
"The attempt and not the deed comfounds us."
RE: redraw problem
BBJT CSWP
RE: redraw problem
