Brass grates
Brass grates
Can anyone tell about advantages of brass grates in onshore plants? Is it better than galvanized steel grates? Are there any disadvantages (corrosion, strength etc) in using brass grates?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Brass grates
Mike McCann
MMC Engineering
RE: Brass grates
This may not be valid in your application.
RE: Brass grates
Money.
Money.
Money.
Few things will be more expensive than large brass castings - especially if only a few are going to have to be made to a specialty low-quantity order.
Brass will be significantly weaker than steel, so a brass fitting will be heavier (and cost more) for the same size, holding up the same traffic weight. If the grates are accessible, just plan on replacing them every 15-20 years. Cast iron street manway covers are capable of lasting dozens of years exposed to all weather and corrosive conditions.
RE: Brass grates
