Sheet number in BOM
Sheet number in BOM
Sheet number in BOM
I have figured out how to use Relations in my repeat region to use conditionals in my regions.  What I am trying to figure out is how to use "&sheet:view:<view_name>" in relations.  I can put it into the properties manager, but I need to be able to change the view_name in the region, so I am using relations.  I have figured out how to use strings like "asm_mbr_type" instead of "asm.mbr.type", but this technique has not worked with the parameter I would like to use.  Thank you for any help in advance.
