centrifugal pump over current
what are some of the common cause for a submiserable centrifugal pump to go over current ???
hydualicly speaking ....
another question .... will a centrifugal pump, pump in the right direction even the impeller is rotating in the wrong direction?? if yes, what are some of the by product of that???
RE: centrifugal pump over current
Bearings failing.
Not enough restriction in flow.
Motor stalled.
Yes the water will continue to flow in the correct direction but you may only get %50 of the flow you are paying for.
Keith Cress
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
Flow x Head = work.
