Calculate Torsion in Sand
I found some equations that discuss calculating torsion in sand where most are for clay.  Does anyone have a preference on an equation or method to calculate torsion in sand.  I have 6 blades (4-foot long) embedded in sand.  The blades will be carrying a theme park attraction intended to move the sand in a large sand box.  It is similar in shape and concept to the Vane Shear test. The equation for the Vane shear is mainly for clay.  I need help finding the right equation to use in calculating the torsion generated, but in sand.
