Bend table questions
What happens if I enter an angle between two angles in the table?  Does it interpolate? I know it does for the thicknessees.
What if I enter an angle in the table that is above the max value or below the min value?  If the max listed is 90 degrees, what happens if I type in 110 degrees?
What radius is used by solidworks by default when referencing a bend table?  The left most column in the bend deduction table, or the last used?
Thanks.
RE: Bend table questions
Quote:
SW Help File]A few items to note about bend tables in a text file:
The sample bend table is provided only for informational purposes. The values in this table do not represent any actual bend allowance values.
If the thickness of the part or bend angle falls between values in the table, the software interpolates the values to calculate the bend allowance.
